help!! I tried the bootloader unlock several times and now my phone wont boot into android just fastboot every single time I've tried the factory reset but it just reboots into fastboot all over again...
So this could be a problem...
You can't exactly unbrick because you don't have download mode... And from what you posted on the other thread you don't have CWM... So afaik, you don't have many options here...although I could be wrong, you might want a second opinion on that.
Are you still getting the same fastboot message on your phone as before on the other thread? If not, what does it say now?
*snip*
Mkay, try this. Unplug phone. Pull battery and put back in. Hold vol up, then plug USB in. Does that get you into download mode?
Great!! I was wondering, if I get this fixed, will I still be unlocked (bootloader)?
No. This relocks and unroots. You'll have to reroot and try the multitool's option Z again.
Wrong, it only unroots. Nothing will relock.
Ok, download the Firmware here: http://oudhitsquad.com/android/LGE/Firmware/MS323/MS32310b_00.kdz Then download the LG Flash Tool here: Dev-Host - LG Flash Tool 2014.zip - The Ultimate Free File Hosting / File Sharing Service
does anyone have the Boot IMG file? A Uploaded link be appreciate
