Root Stuck in S-OFF Help!!!!
evorob
Guys I need help!! My evo that was running on 2.3.3.I decided to unroot because I couldnt get the ota updates and I said to my self no biggie.let me unroot.I was using Z4root (no idea how it worked on2.3.3) WOW mistake.Now I cant get updates,no root,s-off cant get rom manager to work because it says I have no root.I installed pc36IMG.zip on sd card and installed on hboot,took fine even updated and rebooted but still in same position. now what ?????? Before doing all of that I even wiped my phone but nothing. help!!!!!!!!
first off you should never accept an ota or even unroot and accept the ota. all you need to do is flash the stock rooted version that the devs push out. luckily if you accepted the ota you can still root your phone. most of the times the ota will usually will close the exploit used to gain root and then you will have to wait for a new exploit which could take awhile.
second we need to know where you are at right now. what is your hboot? power off then press and hold power+vol down. also do you have s-on or s-off.
Theres NOTHING in an OTA thats worth unrooting to get.
Wait a week and either 1) the developers will have it baked into their roms or 2) there will be a stock ROM with it updated you can flash.
Ok guys it says,supersonic evz-3 ,ship-off,microp 04if,radio
2.15.00.11.19. Now I know that OTA isn't worth the hassle !!!!! Thanks for your help !!!!
correct,I have no root. Hboot- 2-15.00.11.19. As you can tell i am new at this but very interested in learning.
well you have s-off, so you are partly rooted. do you have a custom recovery? go into hboot and select recovery. do you get an exclamation point with a red triangle? if so then try and run revolutionary again. if that does not work we can try a ruu to get you all the way there.
ok,I want to do it right from the beginning.Maybe their is something im doing wrong.Can you please let me know the correct steps for revo. Because when i try to install any zip into recovery it will not let me. It says instalation aborted.
If your trying to reflash revolutionary you need to run that from the computer and not the phone. From the phone you will flash the ROM
Read the guide 2 times and follow it. Ocn did an excellent job discussing all the steps. This is you best shot
sorry,dumb question! do i unzip ? Normally I have always downloaded and copied to sd card.This is new for me.
ok I was able to try to run it and computer gives me message, revolutionary.exe-unable to locate component. adbwinapi.dll was not found.
