macmittereder
I've had this Optimus V for a very long time and so I decided to sell it, well the kid did something and now its stuck in this weird loop. He said he was deleting images from his SD card that he put in the phone and he went to restart it and it started doing this loop thing.
The phone was running CM9 or 10 and flashed with a recovery that started with a X I believe, if the information is needed about that I'm sure I can dig it up but when you turn the phone on it says:
Android System Recovery:
Formatting Data...
Formatting Cache...
Factory Reset...
Rebooting...
And then goes to the LG screen and continues on the cyanogenmod screen where it does nothing past that. When I try to go into recovery it just says the formatting stuff again and restarts. Sort of at a dead end and need some help
Formatting Data...
Formatting Cache...
Factory Reset...
Rebooting...
