followed the jsuh instructions for putting 2.2 on eris and now the android keeps shining and nothing is working if anyone knows how to make my phone work again i would appreciate it also computer can tell that something is plugged in but wont recognize it![]()
Did you previously have a 2.1 ROM using apps2sd installed? If so, then the ext partition on the SD card will cause a problem with a 2.2 ROM. You'd have to remove the partition before a 2.2 ROM will work. To remove the partition do the same steps you did when you created it, but set the values to 0k. Note that this WILL erase all data on your SD card, so be sure you've got a good backup.
Good stuff...hey, since I've never partitioned my /sdcard for apps2sd, is there a way to tell that you've partitioned it? (i.e., how do you know except for having done it?). Just curious...
