Root Stuck on Cyanogen logo
Gaanjaa
Crap, I ran into a problem. I'm not the best tech with these things, so I probably should've taken more caution.
I did the mod once, and re-did my back up, because of my contacts, and went to re-do it again, but didn't follow the same steps I did the first time. Either way, now my phone is just stuck at the cyanogen (mod) 7 screen, I've tried to get back into ClockWork, but I can't, it just goes straight to the Huawei, then Cyan logo.
Help please, I shouldn't have done this crap at 6 in the morning, and now I'm supposed to making calls in a few hours. I'm an idiot.
I don't own this phone so I apologize in advance...
Sounds like you didn't wipe before you flashed. Try manually booting into your custom recovery, wiping data/cache/dalvik cache THEN reflash the ROM.
Once again, I don't own this phone but it sounds like that's all your problem may be.
How would I manually boot into custom recovery? I can't seem to do anything, but get stuck on the logo.
Since I don't own this phone, I'm not sure what the key combination is to boot into recovery. It may be listed in the forum somewhere?
You will need to pull the battery to do it.
Do you have a link to the directions for what you did to flash the ROM the first time?
