Root Stuck with HTC screen... :( please help.
Adding to it its a differet htc model
nope... that should not matter. the serial number on the sd is the important factor when creating the gold card,and it will be the same no matter what phone is used if you use the "gold card helper" app :)
Hi All.
Thanks for all the help, my phone is now back online, wahooooo :)
1. Created a new goldcard using 8gb microsim from another HTC.
2. Re locked HBOOT
2. Load RUU_Ace_Sense30_S_HTC_TUR_3.13.468.2_Radio_12.65.60.29_26.14.04.28_M_release_227499_signed
3. And it accepted it, phone got restarted an all is well.
Again thanks for all the help.
Cheers
Sorry I never got back to you yesterday (was ill and fell asleep pretty much as soon as I got in).
Good to hear that you're all sorted though!! :)
awsome! now that you are up and running,and know that youh ave a working gold card,we can change your main version so you can run a different ruu,or you could always run the aahk for a proper downgrade and root,s-off,superCID.
htcdev is a pain,IMO
if you do decide to re-unlock using htcdev and keep flashing roms,just make sure you fastboot boot your recovery and they should flash correctly. prolly want to keep track of your gold card and the ruu that flashed-just in case you need them again :D
