I'm trying to use an Excel table embedded in a Word doc and need to right click to update a formula. But how do I right click on a Droid Razr Maxx? I'm over 40, give me a break and thank you!
Mary
If right click is available, you should be able to put your finger on the cell and hold it for a long second.
Just remember to use your middle finger when you do that, so the app will know you intend to right-click.
(kidding)
(kidding)
Middle finger is for the wheel mouse, you should use the ring finger for right click (the front camera can see which finger is used) ;-)
