R4V3NCL4WD
The data and wifi icons are have been grayed out for the past few days. They used to be blue. I read that this has something to do with being connected to the Google Services/Servers but my Gmail & Play Store apps are working fine. I'm just worried that something else is wrong.
The problem started after I improperly installed a Cyanogen Mod nightly build ROM. I've done this properly before via Clockworkmod but I did it a different way, via CW Updater, and the phone was messed up. At first I couldn't even get it on, then the lock screen kept turning off, then the screen kept turning off, etc... Then I noticed the issue with the data and wifi icons and that the ROM didn't have a Gmail or Play app. I rolled back to the version I had and discovered that the Gmail and Play apps would turn off seconds after starting. I finally did a factory reset. Now everything is fine except for the icons.
Is there an issue or can I just ignore the grayed out icons?
