your best off with the eng hboot from the turn your phone into evo 3d thread... all of the jellybean roms (latest ive heard) work with engI'm trying to find which Hboot I need to flash a jellybean rom. I have 1.57 but I can't seem to find a Hboot 1.5 or older that will flash to my phone. They all try to flash and fail. I'm not sure if I'm getting the wrong file or what.
hot boot???I've followed the thread. My phone has had everything done to be an evo 3d. I'm attempting to flash in hot boot but it errors
hot boot???
I am on engineering boot myself and I know for a fact some roms will not boot on it. they are all sense 4 roms. But every jb Rom without sense works fine. Any reason for this?
You answered your own question, Sense 4 requires the new hboot.
Durkta durrrrr. Lol
We can always just flash the hboots any time once we are s-off in the boot loader screen right? Never needed different hboots for roms.
That's right. If you are s-off you can change it whenever you want. Only takes a minute.![]()
Soo that's mean you can go back to 1.5 hboot if you on 1.04 hboot
Yep!
I didn't knew that I thought you gonna be in that hboot forever and sorry I'm a noob and how do you do thatAwesomeI didn't knew that I thought you gonna be in that hboot forever and sorry I'm a noob and how do you do that
If you want to be a guinea pig and try this out, I put together an hboot 1.5 for Evo V. Just keep in mind it's my first time for evo v and I can't test it out first. Aren't other people running jb on an Evo V hboot? Are you sure you need 1.5? It's up to you (or anyone else I guess) if someone wants to test it out. It should work though.
See Below for download link
the only thing is that when you go into recovery mode it tells you to format your partitionIt works for methe only thing is that when you go into recovery mode it tells you to format your partition
Yes I was able to go to recovery now and thank you again I know you place the file in the sd card and told me to update soo I did and then it told me to boot I did I got scared for a moment cause it took to long too boot lol but it got the job done I hope for any body try this won't give them a boot loop or brick but it works for me soo it should work for every one and I did the command like you want me to do and I got the sprint cid number and ALSO note to anybody that's upgrading to a hboot and when you go into recovery mode its gonna say you in safe mode its gonna tell you to format all the partitions to get to you're New hboot soo that's mean you have to reflash you're Rom again and to get you're hboot that you just put
It told me that I got to format my partitions when I got into recovery mode and SPCS_2
Okay. That might be what the problem was. You shouldn't need to flash this through recovery. You should only have to boot into bootloader with volume down+power and then it will ask you to update.
Also, the SPCS_002 is actually the VM cid so it looks like the sprint cid worked anyway. I don't know if it asked to format because of the different cid or because you did it through recovery? Next time you change hboot just do it through your bootloader and not recovery and see if it works better for you. Thanks for helping me test this out!![]()
