Root Swap Themes
Bankswood
Android Expert
Guys, as I stated in an earlier post I am new to installing themes. I am running Bo's deodexed .596 and I installed the Watermark'd theme on it. I would like to try a different theme now. Can I flash over the existing theme? Do I need to flash a fresh .596 first? Can I flash a nandroid of my unthemed .596 then flash the new theme?
You can, but I suggest you apply the deodexer again, and then apply whatever theme you want after that.
Bo my nandroid is your. 596 deodex. So if I flash it I should be good
Sometimes those backups are finicky. If you have FC issues, apply the deodexer after restoring, and even if you don't have FC issues, I still suggest you apply the deodexer again.
