Root Swiftkey X Language Pack Removal
LittleRedDot
I'm trying to find and subsequently delete the unnecessary language packs from this app... Can anyone help me? I've tried going through sd card and via root explorer, but have yet to find them.
Not sure what you're looking for. When you setup Swiftkey, you download your language pack then unless you want another language pack, English (US) would be the only language pack you have. I believe Swiftkey allows up to 4 language packs to be downloaded. If you're looking to delete the module, it should be under the folder 'swiftkey'
a little off topic but, i love this app.... i especially the way the numeric pad comes up, instead of on top, all in a row, it's grouped like a calculator... plus, voice input works great too...
YEP! I can't get any of my android peeps to give it a try, they all want their keypads to look and feel like an iPhone.... yuk, so boring
