From what I've been told, you cannot remove an account once it's been added without doing a factory reset. Makes a lot of sense, huh?
Yes. I use Google Apps with my own domain for my email which is the original Gmail account I had on the phone. I wanted to use Google Voice but at the time it was not supported by Google Apps so I created a standard Gmail account just for GVoice. Now it is supported so I added it to my Google Apps account and tried to the delete the regular GMail account off the phone but it won't let me. I get a message that it is required by the phone and can only be removed by doing a factory reset.Have you actually tried?
Menu -> Settings -> Accounts and sync -> press the account -> [Remove account]
Not for me. I added a secondary Gmail account and it won't let me delete it.After some research, I'm pretty sure this only has to do with the account you use when you initially set up your phone (the account that gets tied to the Market and some of the other Google apps), but not for additional accounts you add.
For example, just as a test, I added my wife's Gmail account under Accounts and Import. After it was successfully added, I successfully removed the account (without a factory reset). However, if I try to remove the account I used when I initially set up my phone, I get a message telling me I can't.
