Help SWYPE...not again!
potterdood
I've had swype since I 1st got my Dinc. 1 time the beta ended and they started a new 1. Well now my swype is doing the same thing again. Anyone elses not working either?
What is the "same thing" that it's doing? Check out the FAQ on the Swype Beta page, has some helpful hints on re-installing.
Well, it's a closed beta, what you have is an unofficial leaked and would be considered illegitimate and/or piracy. There are ways that you can circumvent the beta period (see their FAQ) but that's just about all the support you will get around these parts since the developer requested that the program not be shared outside the beta program.
Officially i recommend waiting until it's official and not beta (not that that will happen).
Unofficially I suggest you search to find one or support in other locations...xda site perhaps ;) ...
Sent using swype w/ speak to text
