Help Swype on thunderbolt
You need to be part of the beta program. If you are, then you can download the installer at their website.
You can't get swype unless it is built in or you are in the beta program. You can try shapewriter or ultra keyboard as an alternative.
I was previously using Swype with my Eris. I went back to the Swype website and reset my phone info (a process that can only be done once BTW). I then downloaded the Swype APK installer, which in turn installed the Swype Beta full version. Then it was just a matter of enabling Swype and changing the input method and VOILA! I did all this from my TB BTW! Happy Swyping;-)
Looks like i need somebody with an eris to fix this i guess.. I did the same thing you stated with DX though, so thats why i'm screwed..
