AwesomeIT
I'm running White Widow 4.6 with Google Apps installed and JIT on. Not all of my FB contacts are syncing with my phone contacts. For example, my sister is not linked to any FB profile when she should be. The names match up. Most of the people are, but some aren't. I can't find a way to link it manually to her FB profile. All of my contacts sync'd fine with the stock OS.
Anybody else have this issue? Do you have a solution? I had the same problem in KaosFroyo v23 and never found a solution.
Thanks.
Thanks.
