tuanster1119
After rooting, the sync icon in my status bar has been stuck. I've tried doing a factory reset as well as removing all my sync accounts. Any ideas?
Do a reboot.
I'm having same issue after I did a factory reset and re rooted and restored using TB.
Use the guide I posted....
I've unrooted and I'm doing a factory reset now. I'm going to root again to see if I can isolate the cause of this issue.
I think it had something to do with the backup restore. Nothing I can prove I just have a feeling.Ok I'm almost 100% sure that this has to do with restoring from Titanium backup. This problem came up when I installed 2.2. If you're having this problem, I would suggest doing a factory reset then restoring individual applications rather than doing a restore of all apps and system data.
