Help Sync No More
digiddy
I've been trying to figure this issue out, it's happened to me across the two incredibles I've had so far. Basically my gmail will no longer work on my phone. I made sure the passwords were correct on all the different emails and the manual sync won't even work now. This is pretty frustrating you guys have any idea what's going wrong?
-Louis
For the manual sync, are you just pressing the "sync all" button? If so, press on the actual Google option instead, then make sure Gmail is checked for sync. Some people have noticed this randomly gets de-selected every so often.
If it's already checked, you could try deleting the account and then set it back up from scratch. Doesn't take long to do, just enter your login credentials back in.
why i try to delete my gmail account is says something to the effect of that it can't delete it off the phone b/c other apps use it and that I have to reset the factory defaults. I don't want to have to wipe my phone just b/c gmail doesn't sync anymore, or syncs sporadically. Is there any other way??
Try updating your PRL first by dialing *228, select option 2.
If that fails, you can try adding a second gmail account. Some users have found this springs their original account back to life, then you can delete the secondary account.
Then of course, there's always the last resort factory reset.
