MattDawgyDog
I had everything up and running smooth, luckily, took a nandroid and flashed Freedom's aggressive and got stuck on synergy flash screen for atleast 15 min before I pulled the batt and restored nand. Something I'm missing here? Would it have anything to do with the a2sd on synergy and the sense kernel not supporting it? A little help would be appreciated but a rom suggestion should fix the problem! Flashed synergy rom, wiped cache/dav then flashed synergy-dtapps2sd and booted. Everything moved/restored just fine - went back to flash kernel and I was stuck at the synergy splash.
