System/app
jaman29
What does this mean: "push apk to system/app."? I know what apk means lol. I just don't know how to "push" an apk lol.
I'm trying to get the different clocks for gb08. It says to download them, push them to system/app and then set the permissions. I got it now. Thanks:) I wish I could find a way to change the system ui and the quick tabs in the drop down menu to the way they look in ga10. I like the stock colors better than the blue.
Which ROM are you running?
I'm on GB08. I was able to change the system ui. Have a much better looking battery now with better looking icons in the drop down menu:)
I should have been more clear. Were you on a custom ROM based on GB08 or the stock rooted one like what is installed with the one click install?
I am on the one click and it looks almost exactly like GA10 except for a newer version of VVM
Um I am on the GB08 that is in the one stop shop. I installed the gb08 modem, kernel, then rom. I never found a link for the one click. This rom is identical to GA10 except the drop down quick settings were blue. I didn't like that color.
Okay that explains it. The one in the One stop shop it a custom one. I was wondering because I was on GA10 and now GB08 (both of them the stock rooted non customized) and they are practically identical for the user interface.
Can I just flash the rooted one click stock through recovery or do i use odin? I'm searching for that one now but can't seem to find it.
Actually I'll just stick with TBSG3. I have all the tweaks and scripts running and have everything just the way I want it:) later I'll try the stock version. Love the speed of this Rom.
