Why can't I edit or remove system files such as init scripts. I've tried with the terminal, adb, and root explorer. Any ideas? I think I've found a way to over clock stock 2.2.1 but I need to replace or edit some parameter files
For files that can't be edited with those methods how would you go about editing then
Ohhhh I gotcha. So I would have to do a nand back up and then i should be able to mount the img in linux right?
There is a file located at /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_frequently. If we change the value of this file would that not allow us to overclock this device?
Yeah I looked at those values and even tried to change them. I just need to figure out how to unpack the img files in linux. I found a link to some Perl scripts but the link didn't work :/
i think i know what links your talking about. i used the same post to try and understand stripping it apart in a hex editor. still working on getting that understood so i'll let you know if i do. i have a linux setup also though so i might try to mount it on that too
There is a OC kernel posted on a thread somewhere. What is it that you guys are trying to do?
