Root System R/W and R/O script
Fabolous
Superuser
I've modified Pete's sys script to run on the Droid X. Basically, if you install this, you have a very easy way to mount /system as r/w and r/o, and can forgo the extremely long command line to do it.
Credit to Pete for the original script.
Installation
-Download the attached file, and put in on your sdcard
-Fire up adb or terminal emulator
-Do the following code:
Code:
su
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
cp /sdcard/sys /system/xbin/
chmod 755 /system/xbin/sys
sync
mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
That will install the script which basically runs the two commands you typed up above.
How to use the script
Whenever you need to mount your system as r/w, fire up adb or terminal emulator:
Code:
su
sys -rw
go about your business
sys -ro
Download
sys
Fab,
Thanks for the script...
Just thought I'd chime-in with something too... I just pushed the sys.txt file over to my phone with:
adb push sys.txt /sdcard/sysmount.txt
Then, when I want to use it, I just type:
$ su
# sh /sdcard/sysmount.txt -rw
System Mounted Read Write
Works great this way too! (your install is clearly much simpler, but I didn't want to install more than I had to ;)).
Cheers!
thanks fab. i pushed it over to my dropbox so i'll have it on the ready whenever i need it after a rom flash.
