I have an LG-OptV that came with 2.2.2 from Virgin Mobile.
Based on what's posted in the forums I used gingerbreak 1.2 to root the phone.
All was fine up until I got stuck in a situation where the phone won't go into the recovery screen, rather it loops through it yielding the following:
Android system recovery...
Do not pull out the battery!!
Formatting Data...
Formatting Cache...
Factory reset...
Rebooting...
I'd post an image, but as this is my first post, so I'm unable to that just yet...
Background:
Followed the steps in the "Guide to Rooting Without a Computer"
gingerbreak 1.2 rooted the phone just fine
Initially flashed Xionia Recovery zip (blue font)
Next flashed CM7.1.0.1-BobZ ROM (2.3.7)
At this point all appeared to work fine
Went back and reflashed the recovery to CWM_3.0.2.4 (orange font) as I figured I'd be playing mostly with 2.3 ROM flavors
Was getting ready to flash BACKside ROM and began going about clearing the cache, etc. and that's when I got myself into the system recovery loop issue.
The primary hangup is that I don't seem to truly have root access anymore.
I can terminal in, and su from $ to # at the prompt, but any command I try results in "permission denied".
At this point I've tried ROMTools, ADB and FastbootRoot with no success. All connect with the device just fine, and will get and show the # at the prompt, but when it comes time to actually flash a new recovery image it doesn't occur. Instead the device reboots, goes through the system recovery as described above, and boots as if it's a brand new install... All previous data on the phone is wiped. The SD card seems to be unaffected by any of this.
I've also tried to reapply gingerbreak to no avail... It installs, makes a superuser request which I allow, and then generates the error "could not extract assets!"
I have searched the forums prior to posting this but have not yet found this same issue. Apologies if I somehow missed something obvious here.
I'm new to android in general and have been learning by trial and error based on perusing the forums.
Any pointers would be greatly appreciated.
Also wanted to add that Rom Manager has also been tried. App installs properly from the market, appears to get all the correct credentials, downloads and states that the recovery ROM is flashed. However upon reboot the same behavior occurs by going through the system recovery loop and erasing all prior data.
Formatting Data...
Formatting Cache...
Factory reset...
Rebooting...
Background:
