beardiebloke
I just bought a used Hero and so far it works OK except for two things.
First the GPS isn't picking up any satellites from what I can tell. I'll try again tomorrow but it might just be that I'm being impatient and there are too many trees/buildings around. I'm really just mentioning it in case it's relevant to the other issue...
The second problem is more disturbing. After powering on the phone I get this message:
"Install system software update
Would you like to install the following system software update?
System update available (size: 3.02 MB) ... etc..."
If I hit "Cancel" everything still works as normal.
But if I hit "Install now" I get to this screen:
"Android system recovery
- USB-MS toggle
- Backup/Restore
- Flash zip from sdcard
- Wipe
- Partition sdcard
- Other
- Power off
Build: RA-hero-v1.6.2a
Finding update package...
Opening update package...
Verifying update package...
E:No signature (216 files)
E:Verification failed
Installation aborted."
Here's some info from the phone ... not sure if it helps:
Firmware version: 1.5
Baseband version: 63.18.55.06SU_6.35.17.03
Kernel version: 2.6.27-430d1aea
Build number: 2.73.405.66 CL#83173 release-keys
Software version: 1.0.0.A6288
Any idea where I can start to fix this? I've only had the phone for a day so I'm not worried if I have to wipe everything to start over.
Thanks!
- USB-MS toggle
- Backup/Restore
- Wipe
- Partition sdcard
- Other
- Power off
Thanks!
