Root [T-Mobile] Galaxy s4 Issues
settings >>> more >>> developer options >>> uncheck "verify apps via USB" >>> profit.
if developer options aren't listed in more you'll need to enable them:
settings >>> more >>> about device >>> tap "build number 7 times" >>> do the above >>> profit.
Welcome to the forums gowildcats :hello:
It looks like your problem is your baseband and build number don't match. One is MDL and the other is MDB. They should both be MDL if you odin'ed back to stock. Or did you Odin the MDB build?
You can try to Odin the UVUAMDL build. Then go to recovery and wipe data/factory reset.
even if you odin the right rom to the phone it will still show custom not official
you will need to use triangle away to reset the flash counter.
I hold no responsibilty for what it does to your phone.
