Root [T-Mobile] rom decreased internet speed?
akikhia
Android Expert
anybody realize internet speed decrease significantly with a custom rom? i loaded darthstalker v4 and my internet speeds went down the drain im barely pulling 10mbps lte but i always use hspda n im barely getting 1mbps i used to get 35 on lte and like at least 8 on hspda
no issues with me I'm also running darthstalker v4 speeds are the same maybe they are working on your area that's a possibility
thats strange mine definitely went down to at least half i havent even come close to my previous speeds even n a different city
now i barely get more than 0.5mbps most of the time on hspda
Weird what's happening to you I went back to stock and this is inside my room hspa this is better than what I used to get with metro lte :p
what is my apn supposed to be? and how do i check it?
settings > connections > more networks > mobile networks > Access Point Names
Name: T-Mobile US LTE
APN: fast.t-mobile.com
Proxy: <Not set>
Port: <Not set>
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy: <Not set>
MMS port: <Not set>
MCC: 310
MNC: 260
Authentication type: <Not set>
APN type: default,mms,supl,dun
APN protocol: IPv4/IPv6
APN roaming protocol: IPv4
Enable/disable APN: <greyed out unless there are multiple APN's>
Bearer: Unspecified
And make sure under Mobile Networks that the Network Mode is LTE/GSM/WCDMA
