Task Killers and Memory Watching Advice
opplife
Member
Hey there i notice there are a number of apps for dealing with turning off apps that are running in the background and using memory
1. Which is the best task killer app out there?
2. How much memory should you generally as a rule of thumb keep available at anytime?
Thanks
Thanks
I'm sorry but this question is a bit like:
1. Who is the most prolific serial killer right now?
2. How many people should the serial killer leave alive per spree, to retain your sympathy for being a misunderstood individual
1) Don't use task killers - they take up storage space and use battery.
2) As much as you can - uninstall apps you don't use and clear app cache data every now and then.
Nah. Its more like:
1. Who is the best looking female celebrity ?
2. How much plastic surgery is too much before a celebrity goes from shaggable to minger?
:D
ps. 1. You don't need one.
pps. 2. As much as possible.
ppps. In answer to the OP's question not mine :)
ignore the fools who think android was designed perfectly and handles apps perfectly. it wasn't.
Advanced task killer is probably best, BUT it seems to have trouble on Froyo. Works brilliantly on 2.1 and will make your battery consumption next to nothing if set up properl.y
I've never needed a task killer, my phone is always super quick and my battery lasts at least 24 hours.
I am only worried about memory when my phone tells me I'm low. Then I uninstall apps I dont use, clear caches and pine for 2.2 a little more.
How can i clear the app cashe data??
Also what other data should i be clearing??
Ie any cookies via the web??
what needs a good clear out every now and then??
Thanks in advance
thanks for the response
You should read up on how Android manages tasks and you'd see in plain English that there's absolutely no need for task killers :rolleyes:
Actually, it was. The only issue is the applications which are poorly coded which sometimes linger in memory and android can't close, but you don't need a task killer to manage these really anyway.
...and even if you were right, it gives you no right to call everyone fools for having an opinion. Many of us have tried task killers and many of us concur that they waste more battery (by using up more resources than they save) than not having one.
You may see battery life being saved, and performance gain (which I assume is the object of the exorcize) if you run a task killer strictly, but then you can end up causing more issues than you are solving.
Android manages unused apps by putting them into the background with 0% resources, using no battery. This is actually something Android does very well.
so you guys are saying that the KEY point of android: an incredible app store, should be treated with heavy caution and we should severely restrict what we can download? I mean there are thousands of apps out there that are great but are unfortunately coded badly to screw up battery consumption and RAM, so are you seriously suggesting instead of using all of these great apps, I simply refrain from using them, have a very basic smartphone, or instead, use them, and task kill once in a while, so that I have an awesome smartphone??
also don't make me laugh about it using 0% battery when unused. That might be the theory but in practice, too many apps like to relaunch themselves in the background, especially with Froyo.
I don't see where he says that in his post. I also didn't get the memo telling me that the key point of Android was the app store. You sound very angry, have you been getting enough sleep recently?
I'll wade in on this one and give this a big +1
Sorry EmperorKabir but you are wrong. With android 1.5 and before task killers where absolutely essential, now they are more or less redundant. They cause more problems than what they solve.
I suggest your read up on the way Android manages tasks. Your taskiller will use more memory/battery than background/cached tasks.
Yeee haaa, yet another task killer arguement!
+1 for the no task killer side! Waste of time, effort and resources as per all the above arguements.
Thanks in advance
Applications sometimes store data (eg. contact photos in your phonebook, bookmarks in your browser) and cache data (browser history, news stories, etc). Most apps are quite efficient with deleting old or unwanted data, but it's handy to check.
There are 2 ways to do this:
Menu > Settings > Applications > Manage Applications > Menu > Sort by size. Go to the top of the list to your largest applications and open each app in turn. Clear the "cache" if there is an option to do so. (Note: DO NOT clear data from the Contacts Storage app if you have the Facebook Online Directory service activated, as it will sign you out of the directory and remove Facebook friend data)
The other way is using the Astro app:
Open Astro, then Menu > More > Preferences > Cache. From here you can clear cache data from all apps with a single click, and also clear the thumbnail cache too.
My understanding is that cache data is like a Temp folder on your PC and can be safely deleted. I haven't experienced any problems by removing cache data.
