Help Tasker Functions doesnt seem to work!
eugchen
am i doing something wrong?
i created a TASKER profile that will turn on MXPlayer (video player) when my headphones are plugged in...
pretty much what i did was (+) - new task, state, Hardware, headset plugged, Any, then check mark....then new task, check mark, add action, app, load app, Mxplayer, check mark.
when i plug in headphones, nothing happens...
what am i missing?
i have a note 3 with ATT--unrooted
i also did this guide and it doesnt seem to turn wifi on or off...
Profile Name: Home Location
Description: Tasker to-do when I arrive home; This profile switches Wifi on when I arrive home (i.e., outside of the house, pulling into the garage, etc.), and switches it off when I leave.
Context: "State"
State Category: "Phone"
Phone State: "Cell Near" (this was set up while at home, so the cell towers captured the correct location)
Normal Task:
- Action Category: "Net"
- "Net" Action: "Wifi"
- Set to: "On"
Exit Task(s):
- Set to: "Off"
Make sure Tasker is turned on in your Accessibility area:
System Settings (scroll down to System)
Accessibility (scroll down to Services)
Tasker-JB (should be 'On' - if not press and turn on)
I have programmed three simple Tasker programs and all three work well.
Nice, I was thinking maybe that was it but wasn't sure cause it seemed to work with TalkBack which I didn't think was necessary to also turn "on".
I enabled Tasker-JB hopefully mine will now start working as well.
Well that didn't help :(
For example I have A profile set to be silent and set to 8:40 Till 16:00
I just called the phone from my office phone and it still rang...
So frustrating
:D
Maybe we should be looking for help in the actual Tasker forum, lol. My results just give me more questions.
I made the first profile with headphones and MX player. As soon as I plug in the phones, MX pro pops up with a directory that has the only media I have on the device, a short clip I made.
Looking under Accessibility and Services, I do have Tasker-JB listed, but it shows as being off!
One thing I see though, when I look at the profile itself, I see an on off switch looking thing on the right, I have it on.
