"Tasker" is a BEAST! (in a good way)
i made the task manually following the instructions on the wiki explicitly... have i done something wrong?
on second thoughts i'll try the downloads and import and see if that makes any difference
thanks anyway
djdoc1975
<EDIT>
P.S I just realised i had not put the '%HTTPD' (remove comma's) in the text message body and thats why it was sending " i am here"
/DOH just call me homer in future.....lol
grrrrrrrrrrrrr its still not working, not sure what i have got wrong.....looked ot the 2 download links and it just pops up some code, have saved the code but can't get it imported into tasker.....where do i put the 2 downloaded files so tasker finds them?
thanks in advance
djdoc1975
You have to download them from your phone. The downloads have a gps fix which gets you the correct location.
Make a new Profile > name it > State > Mobile network > 3G + Invert
"+" > Net > WiFi > On
(This will turn on WiFi when there is not a 3G connection. If you want to have it turn on 3G every now and then I can help you with that too.)
That is close to what I want. I will give it a try. Thanks!
I have a wifi profile (that I copied from somewhere) that turns on wifi every 5 minutes, and if it sees a known wifi access point, wifi stays on until it no longer sees that access point. If it does not see on, it shuts wifi off and then starts over in 5 minutes.
I want one that does the same except with a phone signal. When one is not seen, shut off the radio for a set amount of minutes. After that time, turn on, look for signal, stay on if it sees one, turn back off if it doesn't.
It wouldn't even need to do anything with wifi, since my other profile is handling that.
I have actually had problems getting Tasker to turn 3G back on after turning it off, but what I have done in the past is this:
New Profile > name it > State > Mobile network > 3G + Invert
"+" > Tasker > Wait > 5 minutes > "+" > Net > Mobile Data On
If you like you can add a time context to the trigger the profile every 15 minutes from 9 to 5.
(This should make the phone wait 5 minutes after losing 3G to try and turn it on again. You can add the time trigger to control how often it looks for 3G.)
I will definitely give that a try. Thanks!
ETA: You wouldn't feel like helping me with this part, would you?
Sure, just tap on the left side (which is the side for all of the triggers) and then select "add" > time > From 9 to 5 and check repeat and set that to 15 minutes
IIRC I believe when WiFi is connected, it automatically turns 3G off and back on when not connected to WiFi.
managed to get them working ( i found where to put them on the sd card so tasker could see and then import them) tested and working except the gps is not that accurate.
eg I live at number 49 and its shows 78 on the text back, is there any way of improving the accuracy? i'm on android 1.6 btw in case that makes any difference.
Thanks in advance
djdoc1975
PS when i just run the GPS it comes back with 6metres accuracy....
Thanks in advance
djdoc1975
Yea, you have to allow a longer GPS fix.
tried from 1 minute up to 5 minutes in increments of 30 seconds it still comes back with number 78. I also edited the gps fix file and changed radius to 10 metres then 20 metres but that didnt work at all so changed it back to 30 metres and now its working again
i'm at a loss as to what to do next....
I've double checked settings and have assisted gps turned on to allow for a more accurate fix.
i recently purchased tasker and finally managed to get it to emulate juice defender (except it's actually much better).
anyway, my problem is, when i switch on the screen i can see that it synced while the screen was off cause i can see new emails at the top of my notification bar, but the led light notification doesn't work :(
so it syncs the emails, but for some reason the led light doesn't go green when it does find new emails... anyone else have this problem?
edit: ah damn just just realized this is the incredible forum, i own a desire, meh maybe the question will still apply
Is there a way to lock a Widget? I am loooking to have a Menu widget and lock it with the pattern lock. Anyone know if this is possible?
Thanks!
Mike
Thanks!
Mike
Not using a pattern lock.
However, you can lock a widget by having the task that it first calls use the LOCK function under the Category DISPLAY. But this uses a passcode, so that each time you press the widget, you would have to enter the code. Then that task calls the Menu task you want.
How do I make it locked by default? I added the Display/Lock to the menu but it only locks when I press the lock menu selection.
Because Tasker's tasks can only be Execute or Menu you need to do it with 2 tasks.
Your "Menu" Task which needs to be set up first, and the "Lock" Task.
The widget you set up calls "Lock". "Lock" needs 2 entries: Display/Lock, and Tasker/Perform Task. In the Perform Task action you list the task name "Menu" that has your menu of items.
The first task "Lock" is execute type, and the second task "Menu" is menu type.
Got it. Worked perfect. Thanks for your help!
I'm using Tasker for lots of things, and I still haven't gotten to learning it's variables syntax.
There's a dual State->Wifi Near and an Application context for switching on GPS when certain apps (Weatherbug, outdoor excercise apps, Navigator) are running. It's set to control my wifi activation for when I'm home, AND when certain apps are running. I so love watching my wifi widget flash off as soon as I've shut down Dolphin or YouTube!
I don't have a car cradle yet, but I have a Time context set to enable it on weekday mornings, as well as disable both bluetooth and wifi during my sleep hours. A brief Time context for the weekday mornings and afternoons enable GPS just long enough to wait until I pull into my work building, so that a Location context can shut off bluetooth and wifi while I'm there, and another short Time context allows it's exit task to reactivate bluetooth when I leave. Sort of complex, I suppose, but it uncomplicates my life when I leave the building at lunch for a walk. I already have an installed app for controlling sound volume and selective silencing of ringtones and notification noises, but if I wished to automate these on a schedule I could add it to this context by pushing a few buttons.
The automatic dial "feature" is an embarrassing PIA when it dials by accident, because you touched the screen after ending a call. This is why the phone app should disappear, rather than linger there after you finish a call. Since the Android developers did not see fit to return me to my homescreen after a call ends, I set an Event->Phone Idle context with the task to Go Home. I've also got a context set for blocking specific callers, and am experimenting with one which records incoming calls.
My favorite is one which shuts off my screen fast when I set down my phone. You can set it to respond in many ways for any position which your phone is in, face down or up as well. Since I hate having to keep my thumb busy on web pages just to keep my screen timeout at an efficient setting, I keep my display timeout long, but tasker will shut the screen off in 7 seconds (it won't set it for less than this) when my phone goes down flat. If you need to use your phone while it's laying flat on the table, it can be set to shut off the screen only when it's lying face-down (my case provides a scratch-safe buffer with most surfaces). This was done under a State->Orientation context, and the task can be found under Display.
Tasker is surely a powerful app. However, my cause to be impressed by it is a bit relative. The fact that it's the best available doesn't mean it couldn't, or shouldn't be better. I am particularly stunned that a paid app leaves no option to selectively activate contexts - you can run Tasker with all of them set to "On", but if you want to activate only some of them for any given occasion, you must delete those which you don't currently want to have running - hardly user-friendly for the most expensive app on the Market! Also, although Tasker can do a lot of things, the fact that I can't set it to do just anything which I would be doing with numerous button clicks does annoy me. A long time ago (at least ten years ago) I played with an experimental Windows application which recorded my button clicks, saving them to be run whenever I wished, with no need to study any sort of script-coding syntax! Why this idea never went viral in the user community still baffles me, although it's understandable that the software companies would never promote anything which would end their ability to sell programs and apps!
You can disable whichever profiles you want - without deleting them. When you are looking at the profile lists, and you see those green check marks on the right-hand side, just tap it and it turn into a red circle with a line through it. This disable that profile until you activate it again.
You can even control the activation of profiles from other profiles using the Profile Status action.
I'm sorry, but I don't know what you are talking about. There are no checkmarks displaying on my Profiles screen, and if you tap any part of the screen you get either a popup menu or part of a profile hides. Long presses give you the Delete option. I've had Tasker on my phone for several months now, but I have recently updated it, and I just checked the Market now, so it isn't that.
You probably need to turn it on in Preferences, I thought it was on by default. Go into Menu > Preferences, and under the UI tab check Always Show Enable Icon.
And if you don't have that option, than which version of Tasker are you using? Because you may not have the latest, although I have had it for several months and have always been able to turn profiles on and off.
Thanks, but there is no option under my UI tab by that title, and the Market shows me no invitation to upgrade (which was done this month anyway). What's displayed there are:
Short Click Action
Long Click Action
Profile List Sort
Profile Name Textsize
Ask For New Profile Name
Confirm Context / Task Deletes
Confirlm Profile Deletes
Haptic Feedback
Show Tips
(and last) Profile Lock Code
