brianr8011
Does anyone know if you can use tasker to read your calendar and then change settings based on a calendar entry (example- My calendar shows I'm in a meeting, so tasker turns my volume off)? Is there a way to do this?
Yep - It's a State Context: Calendar Entry. You can do pattern matching on the title, location or description. You can even select which calendar to monitor. I've got a profile called "Don't Be a Jerk!" that puts my phone on vibrate every time I'm in a one-on-one meeting (title = *1:1*).Does anyone know if you can use tasker to read your calendar and then change settings based on a calendar entry (example- My calendar shows I'm in a meeting, so tasker turns my volume off)? Is there a way to do this?
Thanks!
Followup question- Can it access Touchdown calenders or just Google?
3 easy things to do make the App worth it alone:
1. Turn on vibrate when at work (GPS)
2. Turn up volume and turn on sound when home (GPS)
3. Set phone to silence when placed face down on your desk.
Status
Order issues are overwhelming user support due to the Lifehacker review, please have patience while the backlog is reduced.
I've been using Timeriffic to automate things on my DI, which is similar, but less powerful, as it is basically limited to time of day scheduling. Regardless, I use it to do several things, that Tasker could probably do too.
1. Set all notification volumes to 0% and vibrate ON during work hours. Set notification to 100% otherwise.
2. Turn WiFi on or off at times when I'm at home or at work usually.
3. Turn screen brightness to 100% during times I'm outside or in the car (commuting). Turn it down to ~20% from 7pm -bedtime, to save battery and eyestrain.
4. Turn phone into Airplane mode from when I go to bed to before I wake up. This saves battery in case I forget to plug in overnight.
I've been happy with these settings, but may look in to Tasker for more advanced stuff, like opening apps at certain times (like Weatherbug in the morning), or when I plug in headphones (Listen, Pandora, Music).
I actually haven't been able to replicate one of the features of Timeriffic, which is day-of-week scheduling. When I create a new time-based profile, all it asks are for start and end times.
This looks very promising, I think I'll buy it outright. I have a few questions though for those who use it already
Any information would be awesome.
- Has anyone noticed an adverse effect on their battery life?
- Is there some kind of global setting for how often it checks for conditions (again for battery concerns)?
- Is it easy to set up a delayed text message? What is the basic process?
Thanks!
From the dev's site under user guide:Setting Restorationwhat i cant find is a way to revert all this once i exit out of the navigation....
I know i can create a separate rule that when navigation closes, gps would shout off.
but it has to be an easier(smarter) way to do this.
any ideas? and yes i read the devs site with all the q&a and wikis and examples![]()
I downloaded the demo and I don't doubt it will consume me for the next few days. The possibilities are endless!Single Profile Tasker treats settings slightly different to other actions.
When a setting is applied by the Enter Task, it's value is restored when the profile becomes inactive. For example, if the ringer volume is at 7 and is set to 0 in the Enter Task, when the profile becomes inactive it is automatically set back to 7. In other words, settings are only valid for the lifetime of their profile.
