Hold a TB with two fingers, top and bottom, upright.
Now wrap the battery door with your hand like you normally hold a phone.
Do you see a reduction of voice signal bars? In my specific case and location, I go from three to zero.
I'm curious to see if it's distance to tower affected or that the battery door mounting of the antenna generally causes a significant loss of signal when the TB is held like most people hold a phone.
I know, because I've done that for two HF bands, using a coil in the middle of an antenna (Which acts as a resistive load for some bands).
