Telus sim in a nexus s
Hi i was wondering if I could use my telus sim ( a telus air card sim ) in a new unlocked nexus s from Canada. The sim works on my blackberry but would it work on a nexus s
Thanks a lot
If I get the telus version will it work?
Yes, if you're buying the the phone from Telus and you're on Telus.
Note that you can use any of the Nexus S sold by the big 3 (Rogers, Telus and Bell)or any of the smaller carriers that are own by them and it will all work with each other. They are basically the same phone. The Nexus S is unlock so you can use it on any of the compatible carriers. If you're buying it unsubsidized, you can 'fish' around to find the best one.
