rexdog1888
Is there a temp. root for the TB that doesn't wipe data? I want to back up my data with Titanium Backup before using the ADB root.
i believe that the means needed to even achieve temp root at this stage in the game will wipe the data. but ive been wrong before
if you sync your apps with app brain,will it automagically re-download them after a reset?
Okay, I can't guarantee this will work but I don't see any reason why it won't...but proceed at your own risk.
[Exclusive] How To Root The HTC ThunderBolt And Unlock Its Bootloader | Android News, Reviews, Apps, Games, Phones, Tablets, Tips, Mods, Videos, Tutorials - Android Police
If you follow that link and read through the steps, you will notice that in step 3 you gain temp root. You will also notice that you have not yet performed any action that would cause your phone to lose any data. You are still running the stock firmware, your phone is still usable. Any changes made up to this point will be reverted anytime you reboot your phone.
IMPORTANT: DO NOT...I repeat...DO NOT go past step 3. If you proceed to step 4, you WILL lose all data and flash back to an older OS.
Once you have completed step 3 in the guide:
- On your phone, open the Android Market.
- Download and install Super User (by ChainsDD).
- Download and install Titanium Backup.
- Open Titanium Backup and if you get an error about not having root, click the "Problems?" button at the bottom of the screen and select the "Get Busybox" option.
Once you have backed up your apps...you can reboot to remove the temp root or go on to step 4 in the guide here to complete the root procedure (but I think there are easier and faster methods now available).
I tried it and it didn't work. Titanium backup did not recognise that i had root, busy box did not install, & superuser said "An error occurred and su was not updated". Any ideas on ways to fix this?
Ya it all seemed to work fine but none of the apps that require root would work and i couldnt get busybox to install
Just curious what kind of data do you need to back up for a phone only a couple of weeks old that you couldn't just redo?
