AndroidsOfTara
I am currently running BB 0.5 / ESE53 (don't care about having more than three home screens) and AdamZ low voltage kernel at 800MHz.
I have both SetCPU (obviously) and TempMonitor installed.
I have TempMonitor set to display the temperature in the notification bar with the refresh interval at .5 seconds.
I also have the SetCPU widget on a home screen.
I have frequently noticed that the temperature reported by these two programs frequently differs by several degrees. I have seen it differ as much as 5 degrees Fahrenheit.
Since both programs are monitoring the battery temperature, why is there a difference? Does it have any relation to how often each program is reading the sensor? I can't find anywhere to set the refresh interval in SetCPU.
Should either of these two programs be considered more accurate than the other?
Thanks.
Thanks.
