Hadesminion13
El Final! Read below for results!
I figured I'd post something (somewhat) useful (I hope?) here, since all I've done so far is bitch and ask too many freakin' questions
Alright, so when I was on stock I had to use JD (JuiceDefender) all of the time to make my battery life just tolerable, and it was still horrible. After updating to a revision of CM7 uploaded a few months ago (My phone is quite new, and it's my first Android, so everything was new to me at this point) I had installed JD.
After installing it, my battery life went six feet under and, once I uninstalled JD, it was back to what it was like on stock with JD enabled.
I had seen others with a similar problem, but this had been on an earlier revision of CM7, and I have left JD off of it up 'til now.
With the release of g60's CM7 rev 0.5 I noticed that my battery life was pretty stable. Here are my current stats:
A little comment on this, I don't think 4% for Tiger GBA is accurate, but it may be when compared to the other stats... you'll see what I mean in a little bit hahaha.
As you can see, I have around 9.5 hrs of off-charger time. I do realize that the battery icon is in the charging mode, but that's because I just plugged it into the charger when I realized I should have taken a screen shot. After 9.5 hours of moderate to heavy usage my phone still had 27% battery (Like I said, you can't tell because of the charging symbol).
What do I do on my phone? Well, today was a school day, and my school is block scheduling (Four 1.5 hour periods each day, 30 minutes of lunch, 10 minutes of break in between each class [This includes before lunch]).
We do have wi-fi, but today it wasn't working for me and I don't get service in my school building, so I turned on airplane mode after first hour.
My life story:
Summary:
Total:
4.75 hours Tiger GBA.
7.3 hours music (Probably ****ed the addition up, not sure rofl).
2 hours idle with nothing.
(Music and GBA are both separate and together at different times, see Summary for more info on timing).
As you can see, I just about drained my Triumph with music all day and semi-drained it with Pokemon.
SIDE NOTE: YES, I LIKE POKEMON, OKAY?! I'M 16 AND PLAY POKEMON, SO?! It's a fun and addictive game!
Sorry for the info overload, I just want to make it clear that that's what I did today without JD on. I'll start over tomorrow and do the exact same thing but with JD enabled, and no life story this time because it'll be the same.
[TO BE CONTINUED AND FINISHED WITH RESULTS]
Finished!!!
Alright, here are the results:
All I can say is wow. I did the same exact things as yesterday, except instead of idling for another hour I had to rush it to a charger, immediately before taking this screenshot, only because I had realized that my battery was completely drained.
After an hour less than last time, and I'd say even a little less GBA and an hour and a half less music (One period I was testing and didn't wanna grab my headphones from my backpack 'cause I'd look suspicious), I have ~5-10% battery level as I'm typing this, and my phone is currently charging.
The verdict? JuiceDefender doesn't defend jack sh*t, or at least not on CM7. In fact it helps to drain your battery even faster than normal. This may just be for me, but if you want my opinion do what most of the comments on this thread support and...
Don't throw JuiceDefender on CM7, if it should be used at all save it for a stock ROM!
Thanks for reading! Comments and suggestions on what I should do/should have done differently are welcome.
My life story:
Code:
Without airplane mode:
1st Hour -> for the entire duration of the class, I listened to music and played Pokemon Emerald (STFU, Pokemon is a ****ing GREAT game!), no I don't pay attention...
Passing period->Tiger GBA running in background, music still playing, phone locked.
After turning it on:
2nd Hour->Same as 1st hour, but on airplane mode. Yup, still don't pay attention.
Passing period->Same as last period.
Lunch->Skipped lunch, hung out with friends, listened to music for the entire duration of lunch, Tiger GBA for about half.
3rd Hour->Just music, needed to work on a design for graphics :D
Passing period->Talked to friends, no music.
4th Hour->Turned music back on, Tiger GBA time again, and again for the whole duration of the class lmao.
Done with school!
Off charger, airplane mode off, wifi connected to home network, idle mode for 2 hours. Connected to charger and took screenshot you see above.
Summary:
Code:
1.5 hours of music and Tiger GBA. -> Wifi and service on, no wifi or service.
10 minutes of music. -> Wifi and service on, no service.
1.5 hours of music and Tiger GBA. -> Airplane mode.
10 minutes of music. -> AMode
30 minutes of music. -> AMode
15 minutes of Tiger GBA. -> AMode
1.5 hours of music. -> Airplane mode.
2 hours idle. -> Wifi and service on, both wifi and service connectivity.
Total:
Finished!!!
quilty pleasure hahahaha
