Text Issues with Froyo
Danokan
I am having major issues with CyanogenMod-6 for Hero CDMA - V6.0.0-RC1
I can send text messages but cannot receive any.
I flashed from Fresh 2.3.3
RA Heroc 1.6.2
Did the Wipe Data/Factory Reset
Flashed the Rom
Flashed the Google Apps
Not receiving texts.. everything else apparently working fine.
Did a Re-Wipe and Re-Flash. (Odd thing though.. when I re-wiped and re-flashed, I found some of the apps that I had downloaded still on the rom???)
Tried again to no avail.
Flashed my Nandroid back-up back to Fresh 2.3.3 and received all of the text messages immediately.
Any help?
Used Handcent on the first try to no avail.
After re-wipe used the stock messenger to no avail.
No text messages.
No text messages.
No issues here, not sure. I'm running the 819 and still have not run into issues. The only thing I can say is try the 819, wipe data, cache and Davlik cache:confused:
Try deleting the data in your messaging app, then reboot phone, maybe that would work
