Text Messege Notification
jabooh1
Member
Is there a way to get a pop up notification for a text? Or something like on the iPhone where it notifies you that you still have unread msgs on the app itself?
My problem is I clear the Notification bar and don't realize i have a txt and then never see them.
SMS Popup is the app I use for that. Find it here:
chart
launcherpro app will show you that you have a message.
I have one unread, it shows on the message indicator, even though I cleared it from the dropdown list thingy.
