Help text to speech
I have the metro pc huawei ascend M860 and down loaded text to speech from the settings, and i a missing a step as i do not see the micro phone on my keyboard, can someone please help me
Also, on my main window, i have 9 screens with icons everything is scattered all over, i do not see my trash can to hold the icon and put it in the trash on the bottom right, or anywhere, can someone please help me
thank you
If you still have the stock keyboard installed, the microphone would be on the left side of the space bar somewhere.
Also, you have to long press on the icon you want to delete. The phone should vibrate and you should then see the trash can. Keep holding on the icon and drag your finger to the trash and take you finger off the screen.
text to speech is a text read back system, the exact opposite of what you want what you want is speech to text. find a keyboard that supports it.
would you recomend any good applictions to download for speech to text?
thank you for your help!!
get google voice and a gingerbread or froyo keyboard (betterkeyboard has a few good ones, though the free versions make a tickking sound on keypress and you cant disable it.)
