Root thd stock kernel supports swap
rhino889a
Android Expert
Yeah our stock kernel supports swap.swap file or partition. And i think i can get the radio on 5gig maybe.
i had a sd card that was formatted fat32 partition 1 ext4 partition 2 linux swap partition 3 downloaded swapper2 advanced setting swap partition mmcblk1p3 now i have 1gig swap i opened 20 dolphin browser tabs and still did other stuff with no lag MAKE SURE YOU CHANGE THE PARTITION SETTING most apps for swap are set for mmcblck0 and not mmcblck1 such as ours,
I think it would help a lot if you could make a steb-by-step process, I'm not familiar with swap. :)
You don't have to though, I'm sure there are 1000 threads that I can find off of google :rolleyes:
