blaaze
Things You'll Need
The Method
If you get permission related errors check your phone and hit ALLOW when prompted
Now Install ClockWork Mod Recovery via Recovery Manager
If installation is successful you should now be able to boot into your newly installed custom recovery by holding the HOME key and pressing the POWER key.
If your phone gets stuck at the micromax logo it means that you failed to perform steps 3 to 8. It is absolutely compulsory for the phone to have the flash_image.zip and signed_test_flash.zip installed properly for the custom recovery to work.
Place any or ALL ROMS on your SDCARD and install them via custom recovery by selecting <install zip from SDCARD> and follow specific Instructions from your ROM post.
VIDEO RECORDING CAPABILITIES (increase) by harpayara
How To Install Apps On Your SDcard
(this not exactly installing them on sd rather making a symbolic link on the sd card)
1.download the file from here-[App] Link2SD - xda-developers
2.install the app
3.download the MiniTool Partition Wizard Home Edition
4.install the above software on you computer
5.now connect the phone via usb to your computer and mount it....
6.start the partition wizard application on your computer
7.select the mounted drive
8.right click on the device and select resize
9.resize your sd card to a suitable limit and leave some unallocated free space
10.now select that unallocated space and right click and selct modify
11.now select the format option of ext3 from the drop down list
12.now come to the home window of th software and on the bottom left side you have an option called apply the pending changes,select that.
13.after the changes have been applied exit the application and then dismount the drive
14.power off the phone and then remove the sd card once and then reinsert it again and restart he phone
15.once you are done with that,start the application link2sd and then you are ready to go....link the application you see to you allocated ext2 partition .....
CAUTION!!!!
1.do not link any system app
2.don't link widgets and home launchers like launcher pro or adw
3.and don't link any antivirus app...
go on enjoy freeing up space in the internal memory
Written by borax12 @ xda-forums
- ADB (Android Debug Bridge)
- JDK (Java Development Kit)
- USB Drivers
- Universal Androot Or Superuser
- flash_image.zip
- signed_test_flash.zip
- ClockWork Mod Recovery
- Recovery Manager
- The Stock Rom in case you mess up the phone
- List Of Available ROMs
- [ROM][Stable][23 Dec 2011] Jet 1.0 by varun.chitre15
- [ROM][Stable][04 Jan 2012] Jet 1.1 by varun.chitre15
- [ROM][Stable][31 Jan 2012] Jet 1.2 RC1 by varun.chitre15
- Rom for Micromax A60 8th Jul 2011 by svprm
- sens rom 3rd October 2011 by 1Ishara
- [Alpha][Froyo Port] 5th Jan 2012 by varun.chitre15
- Froyo [2.2] 18th Feb 2012 ported By kjain9878
- [ROM]{20-02-2012} Jet 2.1-First froyo based ROM by varun.chitre15
- New Updated Sense Rom with WP7 style look and lot of improvements
- Stable Froyo Release 8th Mar 2012 by Kjain9878 & fonehackezhs
- [ROM][Freek's][FROYO] 16th March 2012 by -Zfreak-
- [PORT] [Pre-Alpha] [cynogen mod7] [2.3.5] 8th Feb 2012 by fonehackezhs
- [PORT] [Alpha] [cynogen mod7] [2.3.7] 26th Feb 2012 by kjain9878
- [port][rom][cyanogen mod 6] 18th March 2012 by -Zfreak-
- Have The phone fully charged up.
- Enable USB Debugging.
- download flash_image.zip and unzip with winrar or winzip or similar app on your pc and copy the extracted file to the root of sdcard. Download signed_test_flash.zip and copy to root of sdcard (do not unzip)
- Place ClockWork Mod Recovery on the root of your memory card
- Install Universal Androot on your phone so that when you connect to ADB it has superuser rights.
- Install Recovery Manager on your phone to install the custom recovery
- Assuming You followed steps 1-6 correctly you now have to connect your phone to pc in USB DEBUGGING mode and NOT FILE TRANSFER MODE
- from adb shell or terminal (requires root # prompt)
- su
- mount -o remount,rw -t yaffs2 /dev/block/mtdblock1 /system
- cat /sdcard/flash_image > /system/bin/flash_image
- chmod 755 /system/bin/flash_image
- mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak (notice this file install-recovery.sh may not be on your device if it gives an error or file not found move on)
- flash_image recovery /sdcard/recovery-a60-gnm.img (or name of recovery.img)
- sync
2.install the app
CAUTION!!!!
