Help The phone keeps changing what I type. Help!
silver9
The phone keeps trying to correct what I type. Most of the time, I typed it correctly and the phone changes it to something else. Is there a way to make the default action of the phone to accept what I type? I thought I would get used to this, but it is still driving me nuts.
Thanks.
You can try going to menu>settings>language and keyboards>select the keyboard and in settings there should be a "quick fixes" box that is checked. Uncheck it and see if it helps
