Root [THEME] ADVANCED ZVD for LD-LG and #2 *UPDATE1*
No status bar on #2v.1.9.1 from both links
This happened to me after a fresh install of 1.9.1 and this theme to get rid of some elements that another theme left behind. What worked for me was turning the screen on and off a few times, haven't had an issue since. Not sure if that will work in your case, but hope it helps.
dude this is an awesome theme!! i have one question though. how the hell did you change this text color??
i cant for the life of me change it in my mint theme!! lol
Great theme just little issue I have is you put a white and black background and the letters are white so kind of hard to see I added a photo hope you can see what i am talking about.
Also now its saying I ant download instagram on my phone I dont know if it the theme or ld-lg I did have it with all of my roms I just flashed ld-lg then this theme so i dont know whats going on.
In that particular part it is just setup and should only happen after first boot. I dont really consider that much of a problem unless you have found it like that somewhere else? If it does happen commonly please let me know and post another pic and I will see if I can change something! Thanks for bring this up! :D
As far as Instagram I would suggest maybe trying to go into settings>applications>manage applications>Instagram and then clearing data...this will erase all the user accounts etc for the app and you will have to likely re-enter all that but hopefully that should work. If not then try uninstalling it completely and then re-installing it. If neither of those work let me know and I will look further into what could be causing that.
try rebooting see if that helps.
+1 a lot of times after flashing a ROM the statusbar wont appear until you restart again. :D If this didnt work for you please let me know. I have flashed this theme to my phone and several others have as well and its been working for them so if it doesnt work its got to be something isolated to either how you flashed it or something you have on your phone.
Hey Droid, is it possible to change the font of this theme with rom toolbox? And could you tell me the name of the font you use for this theme?, just in case I want to switch it back!..... Thank you for such a sweet theme! :)
I don't know the font but when you go to change the font in rom toolbox just press menu and it'll have an option to back and restore. Just backup this font and you can change it back by restoring it.
I changed this to but don't know which line it is because I just went thru the xml and changed literally every color code :D
But you can change the system font color and still get it
Yes its possible to change the font. Your not going to find the font anywhere around rom toolbox or uot though. Its a windows font I "ported" for android! ;) I cant even recall the name of it atm lol. If you want I could make you a flashable with the fonts and then you could always change them back if you wanted! :)
Thanks Mexjoker for your quick response!....,I will definitely do the back up,,,,thanks.....:thumbup::D
Good job! Goes great with the theme :D Exclusiveness! :P
No Problemo :)
That would work!!!....Thanks for all your hard work!...:D
