Dr0idWhisperer
*Disclaimer: I peronally test my stuff on my own phone to make sure it works but every phone even same kind are different and I am in no way responsible for any damages or malfunctions from the use of these. Do not use if you dont know what you are doing! Also LD-LG 2.9 using on older versions may not work!! Also this theme has been confirmed working on #2 2.4 by Nyrickan Thanks goes to him/her for testing this!
** Be careful which one you download 1st one is for LD-LG 2nd one is for #2. If your downloading for number #2 be aware that this will revert all you icons back to gingerbread ones, the clear button for notifications will go back to the stock position, installs swype, installs LGHome, and the lockscreen will become the slide up to unlock.
THANKS TO: PlayfulGod, V SuperUser V, ShinySide, MrPNUT, & lDrifta
This one the pictures do it little justice but the notification dropdown background is animated. If you flash this and like that feature then the next time you see a post by shinyside be sure to thank him because he told me how to do it!
Also it should be noted that as this was made for LD-LG it does retain some stock elements and it does NOT contain any ICS style elements. So anyways the bootanimation is the blue matrix falling text from rom toolbox (FOR LD-LG only). This also has a full blackout (Contacts, Mms, menu hardware button menu).
I was wanted to say this will also flash to you an impressive amount of ringtones, notifications and alarms. Some are random, all the stock gingerbread ones, all the ics ones, some of the good ones from my past themes, some of the ones from broken out, and all the CM9 ones. I think it was something like 180 ringtones, around 150 notifications, and like 30 or so alarms! Look:
To install ADVANCED ZVD just download the zip appropriate for your rom (either LD-LG or #2) to your SD card . Then you reboot to recovery. Next you go to wipe cache and select yes (be sure NOT to select format data as it is very close to wipe cache). Now you will want to go down to advanced and wipe dalvik and select yes. Finally, you go to install zip from sd card and you navigate to the zip you downloaded and select it then select yes. Let it do its thing then reboot and enjoy!
UPDATE 1: Themed MMS and themed the main dial button to match theme(thanks to Heavyweightgd6 for suggesting), added some more icons back for #2, fixed the 4G statusbar icon (thanks to Johnny Crapple for bringing this to my attention):
P.S. - If you were wondering that was me just randomly swyping around the keyboard seeing what words popped up lol
ADVANCED ZVD for LDLG 2.9
ADVANCED ZVD for ROM #2 1.9.2
ATTENTION: IF YOU ARE HAVING STATUSBAR ISSUES WITH THIS THEME HERE IS A POSSIBLE FIX;
1. TRY THIS FIRST! Look in your build.prop and under his additions @ #3d performance look for something that starts like this: dalvik.vm.dexopt-flags and if you see u=y delete just those 3 characters. Dont worry it wont affect performance at all. LD has already in his ROM thread that this was a problem...coincidentally after reading that I was playing with this and add it and it broke the statusbar...as soon as I deleted it, it came back!
2. ONLY IF 1 DIDNT FIX IT. Just flash this as you would any theme or as per the instructions above and then reboot. Then go back to recovery and flash the theme:
ADVANCED ZVD for #2 Statusbar fix
Questions or comments? Feel free to post here or send me a PM!
Thanks for all your support!!!
Also it should be noted that as this was made for LD-LG it does retain some stock elements and it does NOT contain any ICS style elements. So anyways the bootanimation is the blue matrix falling text from rom toolbox (FOR LD-LG only). This also has a full blackout (Contacts, Mms, menu hardware button menu).I was wanted to say this will also flash to you an impressive amount of ringtones, notifications and alarms. Some are random, all the stock gingerbread ones, all the ics ones, some of the good ones from my past themes, some of the ones from broken out, and all the CM9 ones. I think it was something like 180 ringtones, around 150 notifications, and like 30 or so alarms! Look:
