bouchigo
Android Expert
I installed ApeX 2-0 RC2 today and decided to port BWC for it
I thought it was going to be time consuming, but it was a lot quicker than I thought.
I replaced the Music.apk with the Music.apk from stock GB that myself and Kirbnite collaborated to invert; I did this because the stock GB Music.apk offers lock screen controls as you will see in the screenshots.
I haven't noticed anything out of the ordinary, but if you guys catch something let me know so I can get on it and correct it.
You guys know the usual disclaimers about "you" being responsible for your own phone, etc.
MUST READ before installing:
Check to see if your Market has been updated to v2.3.6. Go to Menu/Settings/Applications/Manage applications, select the "All" tab and scroll to the market. Select "Market", and if it shows you are on v2.3.6, uninstall the update before proceeding to install the theme, otherwise your market will force close and will only be fixed by flashing your backup.
You might want to freeze/rename your MarketUpdater.apk so your Market won't update after uninstalling the update, or so it won't update your newly installed themed Market later on when a Market update is released, unless you want it to update
Updated 6/23/11 @11:15am
Theme Download Link(includes all updates):
http://www.mediafire.com/?ee3i76os1txmief
MD5 Checksum: dc20f66bf93b105fc001c495eb881dcd
6/23/11
Fix white text for username/email when creating an account:
http://www.mediafire.com/?b39sfdhdddzkehi
Fix Accounts closing when trying to add an account:
http://www.mediafire.com/?x1nmoe6hxojn9vv
Add Swype (apply through CWR):
http://www.mediafire.com/?8nw5ixfhj99xame
Disable Slide Unlock when Pattern Unlock enabled
This theme has it.
Mod to remove/add clock from status bar (apply through CWR):
Remove Clock
BWC_Clock_Removal_Stock_GB_4.5.596.zip
Add clock
BWC_Add_Clock_Stock_GB_4.5.596.zip
Market (by me):
Has the latest market v2.3.6, themed Black Market.
TV/CRT Animation:
This theme has the mod
Data Throttle:
Removed data throttle
Dialer One (modded to match BWC):
It comes with the most recent v1.3.3.
Pandora v1.5.8 (modded for BWC)
Note:
When you first install BWC Dialer One it will not match the BWC theme, it will be a gray color. To make it match the BWC theme, do the following:
When in the app, go to Menu>Settings>General settings>Application theme and select the "Black" option, and that will do it
Dock Icons:
If you want the dock icons I am using, search "Tallmin icons" on Google and you will find them very easily.
BWC folder installed on SD Card has:
- "Addon" folder that contains addons such as, BWC Dialer One, Modded Pandora.
- Dock backgrounds for Replacement Home apps and some wallpapers.
** Expect a long boot up after applying (3-5 mins) **
Follow these links for more info. and screenshots:
http://androidforums.com/droid-x-al...ite-chrome-gb-v4-5-596-updated-6-13-11-a.html
[Theme] Black, White, Chrome for Leaked Gingerbread 2.3.3
[Theme] Black, White, and Chrome for ApeX 1.4.0
[Theme] Black, White, and Chrome for Liberty 1.5
Black, White, and Chrome for GummyJAR 2.5
Black, White, and Chrome for Fission 2.4.2
6/23/11
This theme has it.
Remove Clock
Add clock
Market (by me):
TV/CRT Animation:
Data Throttle:
Note:
Dock Icons:
