bouchigo
Android Expert
I've finished porting BWC for GB v4.5.591 (most recent leak).
It's been working good so far with no issues that I have noticed. If you guys catch anything that I missed, please let me know so I can get on it and correct it.
You guys know the usual disclaimers about "you" being responsible for your own phone, etc.
MUST READ before installing:
1. Make sure you are deodexed before installing, otherwise you will be in "force close heaven"
2. Check to see if your market has been updated to v2.3.6. Go to Menu/Settings/Applications/Manage applications, select the "All" tab and scroll to the market. Select "Market", and if it shows you are on v2.3.6, uninstall the update before proceeding to install the theme, otherwise your market will force close and will only be fixed by flashing your backup.
Theme Download Link:
BWC_GB_2.3.3_4.5.591.zip
MD5 Checksum: b274c7428459fe7daf10949868e5a8f0
Music app tab text visibility fix:
http://www.mediafire.com/?pcfg2fn4mcum2u8
Mod to remove/add clock from status bar:
Remove Clock
http://www.mediafire.com/?hz4dum4mwx2n34d
Add clock
http://www.mediafire.com/?wjn4uy3jihin44g
Market (by me):
Has the latest market v2.3.6, themed Black Market.
Settings Menu and Stock Dialer (by me):
Have been inverted to black, no longer the light colored background.
AppWidgetPicker:
Included to clean-up/group your widgets menu.
TV/CRT Animation and 270 degree rotation:
This theme has the mod
Dialer One (modded to match BWC):
It comes with the most recent v1.2.7.6.
Note:
When you first install BWC Dialer One it will not match the BWC theme, it will be a gray color. To make it match the BWC theme, do the following:
When in the app, go to Menu>Settings>General settings>Application theme and select the "Black" option, and that will do it
Dock Icons:
If you want the dock icons I am using, search "Tallmin icons" on Google and you will find them very easily.
BWC folder installed on SD Card has:
- "Addon" folder that contains addons such as, BWC Dialer One, Modded Pandora.
- Dock backgrounds for Replacement Home apps and some wallpapers.
** Expect a long boot up after applying (3-5 mins) **
Follow these links for more info. and screenshots:
http://androidforums.com/droid-x-al...me-gingerbread-2-3-3-4-5-588-latest-leak.html
[Theme] Black, White, Chrome for Leaked Gingerbread 2.3.3
[Theme] Black, White, and Chrome for ApeX 1.4.0
[Theme] Black, White, and Chrome for Liberty 1.5
[Theme] Black, White, and Chrome for Liberty 1.0
Black, White, and Chrome for GummyJAR 2.5
Black, White, and Chrome for Fission 2.4.2
collection of ported themes for fission 2.5.7
Remove Clock
Add clock
Market (by me):
AppWidgetPicker:
Note:
Dock Icons:
