Root [Theme][CTMod3.6] ET16's ICS Theme ("Holo") beta3/alpha4 [UPDATED 5/22/2012]
Holo beta3 + alpha4 for CTMod 3.6
This is a ported version of a theme I made for the Prevail. It is beta because I myself do not own a Marquee :vroam:
I made two versions this time! beta3 has new signal bars that I tediously drew up in Photoshop... :dong:
they look like this:
alpha4 has the new signal bars and experimental battery indicator images and xmls, so tell me if they work properly please :)
Well, here they are:
DOWNLOAD BETA3
MIRROR
DOWNLOAD ALPHA4
MIRROR
and the
OPTIONAL ICS RINGTONES (working now, promise :D)
MIRROR
Both of these are CWM-flashable, but I can't test them. (So I suggest making a backup... just in case :p)
ChangeLog:
alpha4 (5/19/2012) - Modified battery xml's and images in framework-res. Shouldn't have problems, but I'm nervous
beta3 (5/19/2012) - Fixed signal bars to match theme
beta2 (5/17/2012) - Themed MMS, Settings, and SystemUI
beta1 (5/15/2012) - Initial Release
Screenshots courtesy of sik00 and lMonsterl (P.S. I need some new ones if it's not too much trouble :p) :
Thanks man. Downloading!
update: dig the bootani and roboto font. Cant wait for the blue systemui. Dialer is DOPE. BTW the ringtones zip wont flash but the theme does. i just did it manually
Could you add some kinda mirror the media fire link is not working for me, so anxious to see this...
easytarget16- love that boot animation. so far so good. like the feel of this theme. looking forward to having more added to it.
Monster, how'd you get ICS ringtones to work manually?
Oh shit, that's because the ringtones zip was the one I used for the Prevail... forgot to make a new one :D I'll put it up tomorrow, and maybe add another mirror to avoid captchas...
EDIT: Ringtones link fixed :D
Mirrors with direct links added as well
If someone could upload new screenshots, that would be much appreciated :D
Looking nice man...boot animation is smooth. Here's a few. Pardon my cluttered homescreen at the moment :D
Yeah so far so good! I still have the normal battery, signal, and alarm icon. Wifi does change to blue when connecting.
Tried to take a screenshot of the volume sliders too but it wouldnt let me.
Screenshots attached below. Said it couldnt resize them.
Yeah, the volume sliders are tricky... I always had to adjust them, while holding the power button, continue randomly adjusting volume until the screenshot was taken--even if I couldn't see it moving. Takes a few tries :D
But I take it my volume-slider-thin-blue-line mod thingy worked?
EDIT: Also, it looks like the signal bars don't turn blue?
Yep it did, I enjoy it
Monster I would like to know how you made the Dock on the bottom appear as it does instead of the standard ctmod look.
Nope, they are still at default CTMod, white for Google and dark gray for no Google.
Here's the volume-slider-thin-blue-line mod thingy. Matches my tablet now :p
they did not.
Here's a PM i still had from Bionic about those:
Eventually figured it out. UOT saves the reception bar images as stat_sys_signal_0.png and stat_sys_signal_0_fully.png etc.
Located in SystemUI.apk\res\drawable-hdpi
But what actually is shown in the status bar are pulled from images saved as
sprint_stat_sys_signal_0_green_cdma.png and sprint_stat_sys_signal_0_white_cdma.png which I assume are the default images.
Long story short, I just simply renamed the images from UOT. There were only four bars so here's how I renamed them.
Sprint bar 1 and 2 = blue bar 1
Sprint bar 3 = blue bar 2
Sprint bar 4 and 5 = blue bar 3
Sprint bar 6 = blue bar 4
Hope this helps and I didn't bore you with my long explanation lol
