Root |THEME| Droid X Notification Bar/Framework, Detox from XDA
kingnerd
I put the Droid X framework's .apk into this detox theme, and you can get it here:
Apply just like any other update.zip, do not wipe data and MAKE SURE TO BACK UP FIRST.
detox.zip
One without the custom fonts: http://www.mediafire.com/?mgmozyuzy0u
Screenshot of the notification bar/tray:
Thanks to [THEME] Detox Desire for Incredible - xda-developers for the port.
I like it but I wish it would of just themed the taskbar. It kind of ruined my stock music widget its a weird circle now :(
Just verified your second zip file (dinc-motox-taskbar.zip) is working well. :) I had no trouble just applying the update.zip.
Thanks for sharing!
Thanks for sharing!
Can someone post a screenie of the taskbar. Is it the silverish one with the black symbols and green battery meter?
I'm confused. I was thinking the taskbar is the bar at the top of the screen, but the more I think about it, that is the notifications bar. What do you want a screenshot of?
Also, just to warn you guys, this had an adverse effect on a few of my settings screens (see below). Some are perfectly normal (with a darker checkbox like the droid x I guess) but others like this are very dark.
I'll look into that tomorrow... in the meantime if you want to revert, that's fine... how many preferences is it adversely affecting and on which apps if you don't mind my asking?
I only saw it change the settings for Pure Calendar. I think it only affects settings with a dropdown menu (like in my screenshot).
I downloaded and istalled this when you first posted. Everything works perfect and it looks awesome. Only thing is in stock music app the text and shuffle/repeat buttons are too light. If you could shade these slightly darker it would be perfect. Thanks for altering and sharing this with us!
Yeah, I thought I broke my phone, squealed, dropped my phone, and realized that the Gorilla Glass is in fact 10x better than anything iphone has.
j/k but in all reality: power control is quite FUBAR
Im loving it. However the colors for the signal strength wifi and gps were hella hard to see outside. Are these something easily changable? Thanks for your work and the original authors work!!
It's an issue with the DInc port of detox. I'll try and get in contact with the original author, he claims to know a fix.
Alright, well I have some leads on this. I need to go the airport, but I'll start trying to fix it ASAP. Thanks for all the patience and support guys!
Can you upload it for me so I can merge all his fixes in? He's still uploading on XDA, apparently the last link was bad.
Sorry I missed this post. Should be up now but let me know if you still need it. I have the 0.2.1 before and after the Power Control fix.
Another screenie for fun :cool:
I first want to say that i love this theme, it almost has that espresso style launcher.
I also wanted to see if it was possible for you to make a Moto Droid(the original) style taskbar?
Thanks again for all hard work!
Sent from my Incredible
