Root [THEME]Icecream Sandwich v1
varun.chitre15
Android Expert
Many of A75 users were eager to get a sip of coldness of Icecream sandwich on their A75s
Well, now the wait is halted!!
Here is the first installment of ICS holo theme for A75
Let us see some screenies now
Link--
ICS Holo theme
Instructions to flash
1. Download the zip
2. Reboot to recovery
3. Flash the zip, don't wipe anything, just flash it
As Jet 3.0 being odexed I have made adjustments in the flashable zip which I guess will make it compatible for only Jet 3.0
However UB-1 or any other ROM users may test it and report back on the thread
Thanks to kumarabhishek for testing and Screenies
Note: This is v1 of the theme and it is incomplete yet and will receive updates, patches with time.
As you all can see the network icons look odd, then reason is there are no ICS image alternatives for them being A75 a dual sim phone
Hence, i am going to design some icons personally then I will patch the network icons in future versions
Being v1 lots of things are undone and some hundreds of modifications are left
So keep an eye on this thread and the day it becomes complete, I will hang it on JetMOD 3.0 thread's theme section
Credits and resources
1. D3odex3dAyush - FOr lockscreen pngs and status_bar_item_background.png and buttons
2. Micromax- Pure Funbook framework
BETA RELEASE(Only for experienced users)​
v2 beta 1 09/May/2012
Code:
1.[Fixed]The black text issue
2.[New]Some more theming
3.[New]Transparent status bar dropdown
4.[New]ICS transitions
5.[New]ICS style Boot animations
6.[Improved]Parsing of theme
7.[New][Beta]CRT Animation mod integrated.
Link to v2 beta1=[URL="http://www.indiasporting.com/apks/Varun/A75/ICS%20theme/ICS_holo_beta1.zip"]ICS-holo_v2b1[/URL]
This beta is still untested, I need screenshots and reports
STABLE RELEASE​
v1 08/May/2012
Code:
1. New ICS style lockscreen
2. New seek bars
3. Completely revamped status bar drop down
4. Revamped status bar
5. System wide ICS-sing
6. New check boxes, check circles
7. Transparent popups when pressed softkeys
8. New Dialog box window
DUDE ! U ROCK ! nnnn.....MUCH MORE EXPECTATIONS !! ;) especially the lockscreen needs a more mature look ! nnn ....is it possible to fake a face unlock ?
only problem is text editor is fully black unable to see anything
unable to read .txt files its fully black
Just Installed. Looking very Nice, Nice Unlock method
Main drawback is the Black font on slight a black background. Difficult to view under Sunlight.
I hope u will rectify this.
wonderful theme...btw,How to get back old screen?previous one was more functional...We could go to msgs directly from the lock screen
v1 08/May/2012
Code:
2. New seek bars
where to download v1 .....?
I mean the updated version ...
lock screen too good,
but if i add new contact detail there is everything is black font color as wel as background.
infect i typed my friend name but no any text color is there only show black color only.
please resolve this issue.
I cannot fix anything unless anyone gives me screenshots of bugs :p
LIST OF BUGS-
1)At lockscreen, the digital clock color has to be changed to white.
2)Lockscreen has to be more mature( U may try to integrate a lockscreen that i mentioned in my http://androidforums.com/micromax-a75/545732-complete-ics-makeover.html Tutorial... :D
3)The font bug that was stated by others :rolleyes:
4)The slider looks can be improved.:)
5)the glow can be made cyan in color instead of orange
Suggestions-
1)the notification panel trasparancy can be added !
2) and as u said 100s of tweaks....well thats all from me :p
I JUST WISHED THANKS BUTTON CLICKED ITSELF, BUT SINCE IT IS NOT DOING IT, U MAY HAVE TO DO THE FAVOR URSELF! :D
LIST OF BUGS-
Suggestions-
1. Fixed it ;)
2. Nope its the original ICS style lockscreen so thats OK :p
3. Fixed ;)
4. Need time, will be there in v3 not v2
5. Done ;)
Suggestions
1. Done ;)
How to unstall the holo theme?
I want the previous lock screen..
That was more functional... We can go the msgs directly from there...
New v2 beta 1 is upppp!!!!
Check it out and report back ;)
this is how the original lockscreen is meant to look like...:p
http://developer.android.com/sdk/images/4.0/lock-lg.png .......it doesnt have that speaker thingy....theres just a lock button at the middle ( BOTTOM HALF) :D
Just replace it no ! matter solved !
and......v2 ? sounds interesting.....hope it comes fast ! :thumbup:
This lockscreen is never possible :p
Hi varun. Thanx for all your hard work. Network icons need a change though....looks like a smelly-black-rotting-banana among a bunch of cute puppies :p cm7 like cyan interface is the main need...the extra options that come up in it...if provided by you, would be like more icing-to the icecream theme!
