Root [THEME] IceCream Slider
I've ported YouDug's ICM Theme to the Optimus Slider. Flash it as you would a ROM.
I prefer if you flashed it on the Gelato ROM, but if you have Mobster ROM, i've been told it works on there too.
I have attached some screenshots.
Happy flashing!
If you don't know here is what you do.
Get into recovery mode (Volume Down + Camera + Power Button)
Wipe Cache
Advanced -> Wipe Dalvik
Flash the zip.
Profit.
Made several changes, but some couldn't have been done without the help of tylermich7. jcole20, and fenixfurion)
  • IceCream Slider v1.2.zip
To flash it like a ROM means you need to use a custom recovery to flash in the "install zip from sd card" option. If you don' have a custom ROM but are rooted check in the All Things Root Guide sticky for a guide on how to get a custom recovery installed.
