Root [Theme] ICS for Monster 5.3 Come and get it!!
I've taught myself how to theme with ninjamorph and things look good I just can't change the .9 pngs
in order to mess with .9 images you have to decompile the apk then edit the file then use draw9patch to patch the image and then recompile the apk. its a pain in the ass and by far the worst part about theming. if you dont do all that than the image will be all garbled up and wont look right at all
Won't be able to do that with the morph I don't think lol. I really can't make a good theme without changing those stupid .9s
I'm learning slowly but surely tho:banghead:
Streicon its the dev for that apo so surely it will decompile the 9s
Anyway I love this theme and am planning on sticking with it until I can make my own.we all start somewhere
lol no you cant do it with ninja I its a big process and you need to go thru it sucks I HATE .9 WITH EVERYTHING IN MY SOUL lol. go here man its where i started it is a great guide to start to learn from.
https://docs.google.com/document/edit?id=1-YFrDqBjk7U1w0RIJgvmwH7_famvjxUO9grFR9C15rA&pli=1
I have flashed 3 times and it bootloops after my boot animation. It goes to a blackscreen for 2 mins then reboots but never starts up. Im on 5.3
didnt you have problems last time? you didnt wipe anything did you?
wipe your cache (not dalvic) and try again it has flashed fine on all the other phones so far. let me know
I wiped nothing and no last time flashed perfectly. I opened cwm and flashed maybe it was a bad dl ill dl again and try
Oh Well, heres Captain Careless once again screwing up on simple install instructions. I forgot that I'm on 5.2 so I'm waiting to see what it looks like after it reboots.
Well now, worked perfectly as far as I can tell, got the blue tinge effect, the only screen I wish had remained like it was is the settings menu's. I liked the multi color effect it had but the blue is great too.
So now you know that it works on monster5.2 as well as the 5.3.
hey paris great work, no surprise here cause your always doing magnificent work, hey is there any way you can theme the lockscreen to ics blue and will this work on monster 5.2??
I guess someone said a few posts back that it works on 5.2 but I never tested it.. you can try but make a backup first. What do you mean theme the lockscreen? Does yours not look like the one in the screenshots? I themed the lockscreen blue and black to match everything
Works great on monster 5.2!
