blaze420916
Android Expert
Nope didnt wrk just tried
Hmmm thats strange
paris8577 said:I guess someone said a few posts back that it works on 5.2 but I never tested it.. you can try but make a backup first. What do you mean theme the lockscreen? Does yours not look like the one in the screenshots? I themed the lockscreen blue and black to match everything
Anyone else having visual defects in the call log nothing major just an eyesore
Oh i meant like the lockscreen pattern. Im not sure if you themed it cause i havent flash it. I will flash this later in the aftermoon.
what defects? tell me so i can fix it. if you are talking about the little black boxes it is because of the faded background. the little box on the right with the picture of the phone is black and because i faded the background of all the menus and stuff it still shows up black because normally in stock the background image is black. I have yet to find the xml change the phone box background to transparent so it doesnt do that unfortunately :/ I my friend am still learning as well lol. Theming can be frustrating at times.
paris8577 said:pattern is not themed ics I never use lock pattern so i never think about theming it lol. It looks like the screenshot below its whatever came with the rom.
yeah the theme doesnt work without the overclock kernal. just tested it out but no worries it wont mess up anything
sexy theme paris
Will work on any monster5.x. He used the framework from monster 5.2. I know for sure he did bcuz of the wallpaper. Default wallpaper is a part of the framework res.
Is there any way I can remove the theme without removing monster 5.3?
reflash the rom
I can just flash the backup and it will be gone?reflash the rom
